Does anybody know a option to configure creo to use always the style "hidden lines" for views in drawings?
ok, solved by myself... fyi it has to be defined in the dtl with model_display_for_new_views
How do I edit the dtl?
In Creo: File/Prepare/Drawing Properties/Detail Options - change and you can Save a Copy with the little Dual-Disk icon. Then you can load a configuration with the little Folder icon (<= seems a wierd icon for this!)
Excellent. Found it. Thank you for your help.
Anytime
