decal or color texture is not viewed in Creo View
kachten
7-Bedrock
hello everyone,
When I open an creo parametric assembly in creo view, the decals and textures are not viewed in creo view.
Is there a solution or workaround this problem?
Thx, Koenraad Achten
10 REPLIES 10
Dale_Rosema
(To:kachten)
See if this link helps:
http://communities.ptc.com/message/221181#221181
Thanks, Dale
nope, it does not work. Any other suggestions? 🙂
thx for looking into this 🙂
gr, Koen
save the ASM in Creo Parametric directly as Creo View File (EDZ, PVZ) and open the file with
Creo View.
What's the result ?
Regards kied
Thanks for looking into this.
When I save my assy direct to PVZ-format, the layout is not displayed...
what's about the texture and the the decal ? Do you see anything or only the layout is missing ?
kied
only the layout is missing 🙂
thx!
Hi again,
i think you know the recipe File.
edit the recipe file with the special editor an set the export for layouts / planes.
save the rcp file. and try the export again.
ralf
selvan
 Here i attach the screen shot ,if any one knows to solve this issuequery.JPG
selvan
RandyJones
20-Turquoise
(To:vet_vel06)
We have this same issue here. You can create a fantastic looking decal in Creo Parametric however Creo View does not support showing it. See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS75925 and https://community.ptc.com/t5/Creo-Ideas/Update-CreoView-to-support-viewing-decals-created-in-Creo/idi-p/469998
