delete intralink created parameters
nrollins
1-Newbie
Hi all,
I have parts that are being taken out of intralink and I need to have their
parameters stripped. I cannot find / remember how to do that - But I know
that I have done it before. Anyone know how?
-Nate
13 REPLIES 13
allow_create_pdm_param yes
Mike Foster
ATK
wfalco
(To:nrollins)
system or user generated?
These are system generated parameters.
You saw the suggestion “allow_create_pdm_param” Hopefully that will work, but:
That is maybe a hidden parameter in Creo2? I am not able to enter it using the Config Editor and my experience is that in Creo2, manually editing the config.pro does not get saved… Am I wrong in this? I cannot imagine Olaf Corten using the config editor to massage his config.pro - that would be like tying his hands behind his back. How do I get that option in?
-Nate
Actually, I found this :
let_proe_rename_pdm_objects
Sounds like the same thing but for Creo2?
The let_proe_rename_pdm_objects config just lets you rename the file once you get it out of IntraLink. It doesn’t impact parameters.
Yeah – I just figger’d that out. Thanks.
Hi Nathan,
allow_create_pdm_param yes has always been a hidden config setting but it definitely works in Creo 2.0 M090 – I just tested it. You must be in an unlinked session for it to work.
Edit the config.pro in this directory to load it:
<loadpoint>\Creo 2.0\Common Files\M090\text\config.pro
Then it will load every time Creo launches.
Mike Foster
Awesome – Thanks for your patience, Mike.
It works…
I am thinking that my experience with the Creo session not keeping my manual changes to config.pro had more to do with option order and organization (i.e. comments) Does anyone out there keep a nice orderly config.pro? Creo seems to rewrite the file each time I save it with the order of creation preserved and it ignors my reordering of entries. I like(d) to keep my config organized into section – file locations, mapkeys, import settings, geometry related,… etc. I don’t think that is possible any more. Am I wrong?
-Nate
It doesn't work for me 😞
I added the hidden option to my config.pro, restarted ProE (WF5 M220), opened an old part, the DELETE is still greyed out for the Intralink parameters.
Regards, Hugo.
<< ProE WF5 - PDMLink 10.1 M040>>
Hi Nathan,
The config option allow_create_pdm_param has been around since R200i2.
I just tested it with WF4 M220 and Creo 2.0 M100. And it works.
Just open your config.pro with a text editor and add the line
(yep, I wouldn't do it any other way ... 😉
Now start a Creo / ProE session not connected to a Windchill server.
Open your part and remove all parameters.
Note: you will not be able to delete parameters which are used in any relation.
Remove those relations and you can remove all parameters.
Kind regards,
Olaf Corten
Olaf Corten | CAD/PLM Manager
Besi Netherlands B.V. | Ratio 6| 6921RW Duiven| The Netherlands
T: +31 26 3196215 | M: +31 644548554
- | www.besi.com
To: "Foster, Mike (Goleta)" <->, -
Date: 12-03-2014 14:47
Subject: [proecad] - RE: delete intralink created parameters
Thanks everyone for your help!
I am all set with the task, but hopefully your extra tips will help Hugo…
The “no relations” hint is priceless and could save some head scratching.
-Nate
I'm not sure about "The config option allow_create_pdm_param has been around since R200i2."
because in my text written:
!***TAN 133630 This option only works with Wildfire 2.0 M220 and Wildfire 3.0 M030 and later builds
[cid:image004.jpg@01CF3ECA.B2A509B0]
I jumped a little bit too quick on conclusions. I read the posting of Olaf again, and Olaf is saying the same thing, you have to be disconnected. So Mike and Olaf, thank you.
Regards, Hugo.
