denote a critical dimension
rizzari
2-Explorer
Hi Folks,
What do you do on a drawing to denote a critical dimension? If there is a symbol like a filled diamond for example that you want to use, other then using a drawing symbol is there an extended character set that would work or could you add to the text symbol library?
We use the inspection dimension style to indicate critical dimensions.
Highlight the drawing dimension in question, right button menu >
properties and then in the Display portion, on the left, select inspection
from the radio button tool.
Brian S. Lynn
Technical Coordinator, Product Engineering
We put an asterisk (*) after the dimension, typed into the dimension text.
If you are using basic dimensions then "@[&d@] *" makes it look good (keeps
the asterisk outside of the box).
Mark von Huben
Principal Mechanical Engineer
Cochlear Ltd
14 Mars Rd
Lane Cove West, NSW, 2066
Australia
p +61 2 9425 5210
dgallup
(To:rizzari)
If you are in automotive, TS 16949 tells you to use your customers critical characteristic symbols. Ford, GM & Chrysler all have their own symbols. We supply OE to a couple of other customers and they have their own as well. For products that don't have an OE customer, we have our own symbols. We use 3, one for safety & regulatory characteristics, one for critical fit & function and a 3rd if SPC is required. In all cases, we have the symbol defined and I use an offset attachment so it stays with a dimension or GD&T. I redefined the surface finish symbol to include an optional safety symbol as we have a lot of sealing surfaces that could leak fuel.
