dimension backgrounds in model
dwood1
2-Explorer
I've searched and haven't found a solution to this problem. Just recently "upgraded" from WF4 to Creo2 and dimenison displays in models SUCK. Depending on your background and part color, you either see your dimension or not depending on whether your dimension is on the background or on the part. In WF4 the dimension had a box around it that always matched the background color so no matter where the dimension was, you could see it. I can't figure out how to do that, if possible, in Creo2.
If anyone has a fix to this, I would appreciate it. I keep playing around with system colors trying to find the right combination but depending on your part color, it is either visible or not.
thanks
TomD.inPDX
(To:dwood1)
Welcome to the forum, Dan.
Try enable_transparent_text_bg yes*/no
TomD.inPDX
(To:dwood1)
dwood1
2-Explorer
(To:TomD.inPDX)
You are my hero. That worked like a champ. Thank you so much from myself and the hundreds of others that this is going to help.
TomD.inPDX
(To:dwood1)
Happy to help
