dimension to circle
cjohansson-2
dimension to circle
I am doing some dimensions between circles in Creo.
After selecting the circle I get a menu where I can select center or tangent.
The problem is that this menu appears randomly as it seems.
Sometimes I only get this meny for one of the circles and sometimes for both.
The problem is that I don´t know wether it is the first or the second circle option it asks for.
Or am I missing something?
If you look carefully, Creo 2.0 actually highlights the arc it is considering for tangency.
If you pick an endpoint (vertex), it will not ask about tangency.
2 REPLIES 2
Yes, You are right.
I can see it, but it should have been much better highlighted.
