do you know
dbowles
do you know
Anyone have a way to change colors of instances
Douglas K. Bowles
Advanced Systems Harn/Des
520-746-2019 Office
520-490-9395 Cell
PRIVACY ACT NOTICE: This communication may contain privileged or other
Official information. If you are not the intended recipient or believe
that you have received this communication in error, please reply to the
sender indicating that fact and delete the copy you received. It is a
violation of Federal Law to print, copy, retransmit, disseminate, or
otherwise use this information without prior authorization.
----- Forwarded by Douglas K Bowles/US/Raytheon on 09/15/2010 02:58 PM
Hi Doug,
Up till WF4 it was not possible directly do this. Not sure in WF5 (have not
tried it yet).
There are some work arounds.
One is to assign material with different colour and change those in the
Family table. You can make materials that are just colours if you want. Of
course this causes problems if you are trying to do mass calculations of do
strength/heat analysis.
Another is to make an offset surface from the solid model (if it will do
this) by a very small amount. Then copy this quilt as many times as you
need colours and assign colours to each surface. Finally have
or suppress each of these surfaces in your family table.
Hope this helps.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
On 16 September 2010 09:59, Douglas K Bowles
> Douglas K. Bowles
> 520-746-2019 Office
> 520-490-9395 Cell
> Official information. If you are not the intended recipient or believe that
> you have received this communication in error, please reply to the sender
> indicating that fact and delete the copy you received. It is a violation of
> Federal Law to print, copy, retransmit, disseminate, or otherwise use this
> From: Mike Fredericksen/RWS/Raytheon/US To: Douglas K
> Bowles/US/Raytheon@MAIL Date: 09/15/2010 02:29 PM Subject: do you know
Just to add something to the surface copy method. I've never had the need to offset the surface.
I usually use the SOLID SURFACES copy without offsets.
Rui
On 15.09.
Hi Rui,
I am surprised! When I do this without the offset I get a shimmering
surface of the base part colour and the surface colour. In fact we have
used, and I have seen others discuss, this effect for visually comparing
parts assembled on top of each other as shimmering colour = same and solid
colour of either part = larger than the other.
In any case the real deal for ProE is "whatever works for you" 🙂
New Zealand
DDI +64 3 358 1093
www.taitradio.com
Do you apply the surface colour to both sides of the quilt?
Truth be said, that I have mostly used this with isolated parts...
Rui
On 16.09.
