double window opens same part
ptc-593619
I'm using WildFire 5.0 M060. Here's a shot of my window pulldown.
Observe numbers two and four - I didn't think I should be able to view
the same part in separate windows. I even checked that the path names
were the same - they were. Is this intended functionality?
Richard A. Black
Lead Design Engineer
Eaton Corporation
440 Murray Hill Road
Southern Pines
NC 28387 USA
tel: 910 695 2905
fax: 910 695 2901
www.eaton.com
1 REPLY 1
Yep, that’s what the ‘new’ command (2nd down) does.
Doug Schaefer
LinkedIn
