draft symbol in text
ptc-1140334
Hello again,
I am sure that I have done this in the past but cannot find any notes
explaining how. What is the syntax for calling a draft symbol, maybe a
surface finish mark, from text?
Thanks in advance,
Eric Henriksen
Entegee Engineering
Davenport IA
lwh
(To:ptc-1140334)
&sym(symbol_name)
Eric
Also the symbol must exist in the drawing somewhere before this will work.
&sym(symbol_name)
Dave McClinton
David.mcclinton@mckesson.com
MCAD System Admin.
McKesson Automation
Hello again,
Thanks in advance,
Eric Henriksen
Entegee Engineering
Davenport IA
davehaigh
(To:ptc-1140334)
&sym(symbol_name)
Does that mean the name you see when you switch between symbols & dimensions?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
That is the name of your symbol. (ex. flag.sym.1) You would put "&sym(flag)" in your note, without the quotation marks.
If it has variables assigned to it, you will be prompted for a value.
Hope this helps,
Arnold
