Hi Experts,
In Drawing sheet i need to find the Grid location where the notes is placed. Using VB API, Toolkit Code Or Macro. Help me to find it out.
Thanks in Advances.
Sujithkumar.N
I do not know much about the automated tools other than mapkeys. But, to point you in the right direction, if you select the note, select Move Special, and press MMB, the popup window will show you the current location and allow you to enter a new location if needed.
