This is the article you will find when searching "RealDWG" in the knowledge base: https://www.ptc.com/en/support/article/cs316600
Thanks for reply. But I can open the same dwg file with creo 8.0, which is interesting.
Successful opening in Creo 8.0 is actually good news: you have a working environment.
If we stick to the meaning of the error message, the application RealDWG needs to be installed. But can confirm that Creo 8, Creo 9 and RealDWG are installed on the same workstation?
realdwg is not installed on my pc. I have searched on the internet but I coul not find any installation package.
Where can I download?
Right.
After googling REALdwg, there is information telling it is an Autocad product.
Can you reach out to your Cad or organization administrator? Or some colleagues that kept the install CD?
This dwg file is definitely not corrupt. Creo 8.0 opens and I tried it with different cad software, it opened without any problems.
Yes I am administrator but realdwg looks like software development kit. I can't reach 🙂
@TomU is right.
The article and a deeper search over the internet confirm that this is a third party that Creo OEMs.
Let me roll back a little:
If yes, then either :
All in all, in order to test bullet 2, can you confirm the presence of that executable in both installations?
I just checked my server and pro_dwgconv.exe still exists in Creo Parametric 9.0 but the location has changed.
<Common Files>\applications\REALDWG\pro_dwgconv.exe
<Common Files>\x86e_win64\obj\pro_dwgconv.exe
<loadpoint>\x86e_win64\obj32\pro_dwgconv.exe
