edit supplier name while opening file
ssreevalsan
8-Gravel
When opening a standard part file (typically in .step or .iges format), the system should ask for the supplier's name. We would like to have a drop-down list . This supplier information should then be linked to the part's parameters
Common supplier list
Festo
SMC
Emc
Misumi
Schunk
Schmalz
ABB
Other(manually edit)
2 REPLIES 2
By the way, you can bring all your ideas here - "Creo Parametric Ideas": https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
Dale_Rosema
(To:ssreevalsan)
