can you anyone help me out create evalgraph feature to customize the scale value in drawing.
No need to use evalgraph. For changing drawing scale use the option drawing_scale_factor
Hi This is very useful, can you please explain in detail still having some problem in understand the concept.
thanks,
Define a model parameter named drawing_scale_factor - when you create a new drawing (not from template), the parameter value will be taken as scale.
