evalgraph for Drawing scale
kganesan
can you anyone help me out create evalgraph feature to customize the scale value in drawing.
No need to use evalgraph. For changing drawing scale use the option drawing_scale_factor
Hi This is very useful, can you please explain in detail still having some problem in understand the concept.
thanks,
gkoch
(To:kganesan)
Define a model parameter named drawing_scale_factor - when you create a new drawing (not from template), the parameter value will be taken as scale.
