export to STEP mapkey
BJP
Since Creo 5, I cant automate the export funtion anymore with a mapkey because I always want to export only solid models without surfaces. But in Creo 5, when exporting to STEP, you cant automatically have surfaces de-selected (it only works in one session). Does anyone have a proper mapkey compatible with Creo5 that tackles this?
mcestnik
(To:BJP)
Set your custom export settings for Step in Data Exchange window. This options are later set for every export.
3 REPLIES 3
mcestnik
(To:BJP)
KenFarley
(To:mcestnik)
I've found that the only way I can have my settings default to those I save in the profile is to set, in my config.pro, one of the (apparently new in Creo 4?) options that specifies the file name, such as
export_profiles_step <full path and file name of option file>
Otherwise, it seems the settings I make are only for the current session. Unless there is some other config option I need to make to allow my settings to be persistent?
SJ_9950719
2-Explorer
(To:BJP)
Hey,
I think you should try the BIMDeX plugins for exporting the Creo. I found it very efficient.
