John -
Depending on how many instances you have and how many generics there are, you could pull into session all instances of all generics, and then delete the family table for each generic. (Obviously all from the backup folder). Then save all. This works well for assemblies with part instances, although I have never tried it with assembly instances. Just saying.
In Reply to John Scranton:
I need to send out a family table instance of an assembly. There are also subassemblies and parts in it that area family table instances.
I do not want to send everything if I can help it.
I did a backup to a folder but that saved everything. I only want to get the one instance.
Is there any way of doing this without getting all instances of everything?
John M. Scranton
Manager Design Drafting
and Configuration Management
Ultra Electronics - USSI
4868 E. Park 30 Dr.
Columbia City, IN 46725-8869
*Voice: 260.248.3576
*Fax; 260.248.3509
[cid:image001.png@01CE5D3C.D98B5090]
Internet Email Confidentiality Footer
Privileged, Proprietary, or Private information may be contained in this message. If you are not the intended addressee or responsible for the delivery of this message to the intended addressee, you are not authorized to possess or copy this message or its contents without the authorized consent of an UnderSea Sensor Systems, Inc. (USSI) representative. In such a case, you should destroy this message and notify us immediately. Opinions, statements, and other information expressed in this message are not published or endorsed by USSI unless otherwise indicated by an authorized representative independent of this message.
