fitting_code and specDB
kbittermann
3-Newcomer
Hi all,
I'm currently trying to create a specDB for spec driven piping.
Normally the “CODE” (e.g.: INLINE, INLINE_REDUCING, CORNER, …) will be placed as the parameter “fitting_code” in the part and automatically taken into the auto-selection file (in the spec DB). What could be the reason, that instead of e.g.: “INLINE” there is “NONE” for the code?
Regards, Klara
Current System: Wildfire 4.0 M220
2 REPLIES 2
First what coming to head is something wrong with reading files.
Can be wrong: comma or tab separation in ptd's, some characters in names or patch
Look in creo console messages when adding.
Another thing it can be name of parameter. Try all caps: "FITTING_CODE".
thanks for your answer.
I found the reason why it didn’t work: one of my parts in the family table wasn’t verified. After I fixed it, the fitting_code appeared in the specDB.
