flat pattern for swept blend curved sheet.
AS_9641508
3-Newcomer
I had created this simple part by using swept blend, but unable to generate the flat pattern. any suggestion to do so?
yes, I created that surface in a part. You can possibly covert the flat pattern to a sheet metal part:
3 REPLIES 3
You can use the command "Flatten Quilt" . Create an orflatten.jpgigin point as shown and the flat pattern will be created:
AS_9641508
3-Newcomer
(To:BHOoi)
Let me correct my self. It is not a part it is a sheetmetal. And sorry for the confusion.
