i am facing certaing problems in regenerating the chassis tubings in EFX extension.i want to do a analysis of chassis this wont let me do it.
is there a possible solution to this problem.
the assembly file is attached
Hello Sagar. I am not ignoring you but I have little experience with tube frame analysis. I also do not have the EFX extension available.
However, if you have an active maintenance contract, by all means file a support case.
...and be aware that people with full version Creo cannot open academic versions of files. It appears you only have the assembly in the zip file. Are there not support PRT files needed?
yaa i am using acedamic version on creo parametric 2.0 so can i ask ptc support for help
yes, read this post for a link to academic support page:
yaa i have posted the doubt in support forum thanks for the advice hope they will reply
