We are aware of an issue with eSupport impacting community login. We are working on a fix and community login should be restored soon.
how to create hole patterns using dimensions with relations increment,
thanks
Hello Prashant and welcome to the forum.
Can you explain better what you mean by increment?
I am pretty sure the answer is yes, but maybe not as simple as just having an equation to manage the increment.
For instance... if I want a location series of 1,2,4,8,16 unit spacing, I might have to use a pattern based on points. The points will be defined using relations to locate the point in relation to each other.
* -d1=1- * d2=d1*2- * -d3=d2*2- * -d4=d3*2- * (etc...)
below is the image for your query related to increment for hole patterns,
Message was edited by: Prashant Shinde
