how can delete the parameters in parametric model
suganthan.mech
Hello Buddies
Good Day!!
I need to delete and redit the parameters in existing parametric model(assembly and skeleton)in Proe W3. But I am not able to delete the parameters. Only I can add the paremeters using"+" in parameter table. But "-" is frozen. can any one help me.
Thanks In Advance
Suganthan Rajamanickam
Pro-e System Analyst
Trane Design Centre, India
Ingersoll Rand
You need to comment or delete the relations, where parameters are used and then verify relations. Commenting relations is IMHO better way, since you can later uncomment them and edit. Then you can delete or modify parameters as you wish.
Jurij Škraba
Research & Developement Department for Hydromechanical Equipment
Litostroj Power | Production of Power Generation and Industrial Equipment |
