how can i write beta (Greek symbol) in Creo note?
stimmewar
3-Newcomer
i have been trying to add beta (Greek symbol) on drawing but it changing its shape please help
Sachin,
Which release of Creo you are using?
Creo 3.0: Add B in note, select b and change font to Cal_grek.
Creo 2.0: Add b in note. Enclose that b as middle parenthesis as in {1:b} and select b and change font to Cal_grek.
3 REPLIES 3
Sachin,
what font do you use in the drawing, I mean what is the name of the font ?
  • if it is Creo font (named font, for example) then use procedure mentioned by Mahesh Sharma
  • if it is TrueType font then check if this fint contains Greek characters (in MS Word, for example)
MH
Martin Hanák
Thanks Mahesh & Martin
