HI,
I have an assembly with some parts and that some parts are included in family table (has both generic and instance parts) .I create assembly with the generic parts and now I would like a same assembly with the instance parts by using family table option.
please help me out.
You may have to replace those generics with the instance. RMB on the generic part in the assembly, select Replace and then select the instance that you want to replace with. The assembly will get updated to the new instance.
When you create the family table of the assembly add the component to the family table. If the part has a family table, instead of using the default Yes or No selection type the name of the instance you want to use.
