how to design a pipe for two different id/od size
ptc-6826879
i need to place a hose pipe having two different od size. please suggest guide line
Posting multiple discussions for the same subject matter is not preferred.
It only clutters up the community. Please have some patience for replies.
how to design a pipe having different id size
Vaibhav,
Are saying you want to have a single pipe entity with a certain ID/OD on one end but a different ID/OD at the other?
What are you planning to do for the transition from one size to the other?
I do not believe this can be modeled (using piping) or fabricated as a single piece. The only way I know how to model it and fabricate it is an assembly using 2 seperate pipe parts and an adapter fitting between them.
If you or anyone else knows of a different way please let me know.
Bill
