how to design a pipe for two different id/od size
ptc-6826879
i need to place a hose pipe having two different od size. please suggest guide line
2 REPLIES 2
Posting multiple discussions for the same subject matter is not preferred.
It only clutters up the community. Please have some patience for replies.
how to design a pipe having different id size
Vaibhav,
Are saying you want to have a single pipe entity with a certain ID/OD on one end but a different ID/OD at the other?
What are you planning to do for the transition from one size to the other?
I do not believe this can be modeled (using piping) or fabricated as a single piece. The only way I know how to model it and fabricate it is an assembly using 2 seperate pipe parts and an adapter fitting between them.
If you or anyone else knows of a different way please let me know.
Bill
