how to design a pipe having different id size
ptc-6826879
I've designed a pipe for cooling system, now the stuff is in assembly as both end port are with different OD size.
please brief me the solution
If you are talking about the pipe feature, it uses a consistent ID and OD.
If you need to make an adapter, you must use a more conventional geometry solution.
If you are talking about the framework extension, I do not know about that module.
