Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
6380 Hollister Avenue Goleta CA 93117-3114 USA This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Thanks to Andrew, Carol, Dave and Kelly for each having another take and another piece of the puzzle on the hidden line question. I've seen us all having a hidden line display issues since migrating to Pro/E many years ago.
My final solution in this particular instance was to change the hidden line font to one I'd never noticed before, 'PDFHIDDEN_LINES.' Maybe why I like it as my solution is that part of my paradigm is to create a PDF files of documents I've created. I do not know if this line font is included with Pro/E or if it is a custom created line font.
Worthy of mention is a method to see on your screen what will be sent to the plotter. You go thru a routine where you send a print to a printer named 'screen,' it wasn't the solution I was looking for but proved a useful time and paper saving tool. A reasonable person might think it would be the default... having what you saw on your screen match what came out of the plotter.
Glen R Wisham MOEC EW Mechanical Engineering Space and Airborne Systems Raytheon Company
