how to remove layer tree?
yongjoo
3-Newcomer
Hi this is YJ
I'm using the creo 11 these day. every-things is better than creo 9.
but i got problem on layer tree.
when i open the data i can see the layer tree every time.
even if I turn it off or change min size this. it come up on my screen every time.
somebody help me how to solve it.
kdirth
(To:yongjoo)
After closing the layer tree you need to save a tree settings file.
Select the Model Tree Settings icon, then Settings and Save Model Tree.
kdirth
(To:yongjoo)
yongjoo
3-Newcomer
(To:kdirth)
Thanks for reply.
i did as you said. save a tree setting and close creo program.
but still i can see the lay tree on new creo. how about your croe?
is it program burg?
yongjoo
3-Newcomer
(To:yongjoo)
i found the problem.. my config file was wrong.
i used the configuration from creo ver 7.
so i removed the tree comand  and the problem was solved.
The problem was mine.
thanks anyway.
I think you're screenshot isn't totally correct, the icon you're showing saves a text file of the parameters you have in your model tree. To save the configuration, you need to point on the icon on the screenshot below and point to your creo_parametric_customization.ui file.
