Curious..
is there a way to stop the layer tree from expanding itself?
I find it annoying to constantly have to minimize this tree, as it seem to always want to pop up to be seen..
Not sure why it needs to constantly pop back up after a few commands.. but it does.. Covers the model tree to the point I need to scroll down in the model tree to get back to where I was (part or feature..)
I assume it's because it has a 'self esteem' issue..
Setting config auto_locate_in_tree to NO may help. Set to yes, default setting, the tree will expand and highlight whatever you select in the window.
Are you referring to the layers in the layer tree expanding or the dividing line that controls how much of the model tree vs layer tree keeps moving?
Either way I don't have this issue with the layer tree so there is likely a solution. I do not have the config that @kdirth suggested set either.
Is it that clicking on something the model tree makes it happen? Do you know specifically what click is making it happen?
Hi, yes, the separator between the two trees (Layer & model) to keep the Layers tree minimized.
when I open a part / assembly it's expanded. I minimize it. I then work & such, and it pops back up at some point, covering the model tree..
Not sure what I do to get it to pop back up, as I'm working, not trouble shooting Creo.. maybe after a save? or a re-gen? I tend to flip between parts as I work. So, at some point coming back to a part, I notice it's maximized..
I have the same complaint. Even worse, when I assemble a weldment .asm into a top number .asm using "Seperate Window" BOTH layer trees expand and so my side bar is broken into 4 windows.
Config auto_locate_in_tree no will stop the auto expansion, but will also not highlight anything you click on in the tree.
I also set config floating_layer_tree yes to get the layer tree out of the model tree.
Thank you. I need to keep the auto locate on but I will try floating_layer_tree.
I can't find the floating_layer_tree config but I see now I can pull it out. Thank you.
Looks like they removed it some time after 7.0. I just looked for it in Creo+ (12.0.0.1) configuration editor and it is not there.
