my main objective is to show the machining cost into design template
In manufacturing module i made 9 different assembly, i make the relation to find out the machining time and setup the perameter = maching_cost now i want link those parameter which i has made in assembly to design template in design table.
The machining time that PRO/man outputs is notoriously inaccurate. Machines rapid feedrates, accel decel settings, and setup times would all vary widely from job to job. I hope you can accomplish your goal just be aware that machining time is not a dead on accurate number it is a simple calculation based on the feedrates in your program. I would certainly pad the numbers 20-30% higher.
I wish they would make them more accurate in a future release. Most other CAM systems (even low end ones) that I've used allow you to enter such things and Accel and Decel for both the spindle and the axes, as well as rotation speeds for A & B axes. For such a high end software I'm shocked that they haven't incorporated this.
Is this a variation of your question in post "how to add part's relation with manufacturing relation"
http://communities.ptc.com/thread/54156?tstart=0 or do you mean drawing template?
If you mean the template part, then I see no way to link the parameter from the manufacturing, as the design part to be machined, needs to exist, before the manufacturing can be created, which contains the parameter.
