import jpg (or other format) to take measurements
ptc-267878
wildfire 3 or creo 1
I took a photo of a part, and scaled the image in Photoshop. Is there a way to import it into drawing mode, and take measurements of this part (e.g. radius of curvature) by creating points on the photo? I tried to import it as a BMP object, but the image came in not to scale, resizing changed its aspect ratio, and created points ended up 'behind' the photo. Thanks for your help.
thanks h s
"I’ve done this in the past by creating a surface in a part and adding the image as a texture. I had to scale the surface to get the image right. I then created a curve with the image as a guide."
