in assembly drawing edges of one part not selectable.
rohit_rajan
I have a assembly drawing of two almost identical  parts (made separately) shown by simplified representation. Horizontal and circular edges of only one of the parts are not getting selected for dimensioning.
PTC Creo Elements/Pro 5.0
Windows 10 Pro 64 Bit.
rohit_rajan
(To:StephenW)
for the time being workaround seems to be a config.pro option "select_hidden_edges_in_dwg".
when I switch "select_hidden_edges_in_dwg" to "yes" I am able to select all the edges in the drawing.
9 REPLIES 9
StephenW
(To:rohit_rajan)
Sometimes you just need to regen the sheets in the drawing.
rohit_rajan
(To:StephenW)
Thanks for your reply Stephen. But regenerating drawing sheets did not help.
StephenW
(To:rohit_rajan)
@rohit_rajan
Can you attach the models/drawing or can you attach some screenshots of the drawing and model areas of concern?
As you know, it should just work but sometimes the geometries are not as straightforward as we would like them to be.
rohit_rajan
(To:StephenW)
video uploaded describing the issue. Hope this will give some clarity on the issue. Thanks in advance.
StephenW
(To:rohit_rajan)
I'm not sure, but I think there are issues with dimensioning on offset cross sections (i am assuming this is an offset x-section)
Maybe you can test this by making a quick test view with just hidden lines (no section)
Otherwise, I'm at a loss
rohit_rajan
(To:StephenW)
Its a regular (planar) cross section.
rohit_rajan
(To:StephenW)
StephenW
(To:rohit_rajan)
Interesting, Creo is seeing the edges as hidden and not allowing selection. Glad you found a way to move forward.
rohit_rajan
(To:StephenW)
Thanks Stephen for your help.
