intersection of part surfaces on datum
Ketan_Lalcheta
Hi
I have a part having extrude feature. And plane is also there. on plane, I need to have intersect profile but not able to do complete feature creation in part mode. Attached is sample part file on which I am trying.
What I am doing is as below:
Sleect datum
click on intersect
select all surfaces of part
I am not able to complete this feature. Any suggestion what I am missing on this?
Thanks and Regards
Ketan
tbraxton
(To:Ketan_Lalcheta)
The copy paste is not required. If you select the solid surfaces of the model you can intersect the plane and create the desired curve. See the enclosed part for reference.
Involute Development, LLC
Consulting Engineers
5 REPLIES 5
tbraxton
(To:Ketan_Lalcheta)
Create a quilt by copying the solid surfaces of the extruded solid.  You can do this with the copy paste (ctrl+C->ctrl+V). Then intersect the quilt with the plane. This will give you a stable feature for the intersection that should regenerate if the parents regen without error.
Okay.. I will try this once.... But why directly it's not working without doing copy paste ? It's redundant.... Does intersect feature demand copy paste first ?
Can anyone help me to have updated part with intersect feature ?
tbraxton
(To:Ketan_Lalcheta)
Hi
I tried to download and it has intersect feature . Thanks a lot for this information.
However, I tried to do copy paste and could not create own intersect feature. Also I could not get details from your test part as it has solidgeom feature when I tried  to do edit definition for intersect feature.
Could you please help me with detailed step by step process to create intersect feature? If possible, video is also a better option to share and I could see what all you are doing. If not, detailed step would also work.
I am sorry for this details as I am not much aware about designing. I am more into customization side.
Thanks a lot for your extended hand of support.
Regards
Ketan
Hi
I am able to do so now. Thanks a lot for your help.
