QR Code sketch
Can any one suggest to create the QR code in sketch?
Bar code is created in sketch - Text - Select ID automation font. Does it like that any option for QR code generation.
KenFarley
I think bar code works because it is essentially a font. It's essentially a character substitution. QR code is a 2D matrix that is calculated to represent the data of interest. I think you're going to find that you'll need to generate the QR code you want in another program, and use the image generated in your drawing or model. I don't know how you'd apply a QR code to a part, maybe as a decal?
Maniram1-VisitorAuthor
I read the same in community.
But I would like to make same like bar code for QR code.
Do you know how should take this into PTC support?
StephenW
SamuelBrantner
Hi @Maniram ,
it could be possible to create a Pro/Toolkit application that does the job.
Are you willing to spend money on this?
Greetings Sam
Greetings Sam
Patriot_1776
I did it the easy way:  I fudged something that looked good enough with a bunch of thick and thin lines.  Why waste time trying to make something perfect when it doesn't NEED to be?  Is this going to actually get scanned?  No?  Then it's a total waste of time for both you and PTC to deal with it.  That's what label makers/machines are for.
HamsterNL
18-Opal
August 27, 2019
Why don't you generate a QR code online, then use that image as a decal in a new appearance?
You can then assign that to a face of your part where you want your QR code to be.
