intralink 3.2 help need badly today
JMSCRA
I will not be in here tomorrow if I can help it so I need the help today hopefully. Sorry it is late in the afternoon.
I have a person who I think has a corrupt .proi folder. We are not able to update, delete, export to disc or workspace any file. I cannot as much as delete an empty workspace. I not sure what to do because he has a number of workspaces with a number, in some workspace cases large number, of items that are new or modified some are modified and out of date. Yes shame on him.
We are running intralink3.2 and WF 2.0 on XP machines.
Does anyone have any idea what can be done?
John M. Scranton
Senior Designer
Ultra USSI
4578 E. Park 30 Dr.
Columbia City, IN 46725-8869
*Voice: 260.248.3576
*Fax; 260.248.3509
[cid:image001.jpg@01CA8316.F4F422C0]
">http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="&lt;a" style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="http://www.w3.org/1999/xhtml">">http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html;" charset="utf-8"/>
<title>Untitled Document</title>
</head>
==-==-==-==-==-==-==Internet Email Confidentiality Footer==-==-==-==-==-==-==
Privileged, Proprietary, or Private information may be contained in this message. If you are not the intended addressee or responsible for the delivery of this message to the intended addressee, you are not authorized to possess or copy this message or its contents without the authorized consent of an UnderSea Sensor Systems, Inc. (USSI) representative. In such a case, you should destroy this message and notify us immediately. Opinions, statements, and other information expressed in this message are not published or endorsed by USSI unless otherwise indicated by an authorized representative independent of this message.
</html>
lwh
(To:JMSCRA)
I hope it's in time:
rename the folder .proi to something different. Then start Intralink, which will create a new, empty .proi.
Create a new workspace, check out the project You were working on.
Then, import the required files from th old .proi subfolder, overriding the files in the workspace (override any 'same name exists' conflicts).
That will take some time and manual tweaking, but usually works.
