Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
==-==-==-==-==-==-==Internet Email Confidentiality Footer==-==-==-==-==-==-==
Privileged, Proprietary, or Private information may be contained in this message. If you are not the intended addressee or responsible for the delivery of this message to the intended addressee, you are not authorized to possess or copy this message or its contents without the authorized consent of an UnderSea Sensor Systems, Inc. (USSI) representative. In such a case, you should destroy this message and notify us immediately. Opinions, statements, and other information expressed in this message are not published or endorsed by USSI unless otherwise indicated by an authorized representative independent of this message.
I hope it's in time:
rename the folder .proi to something different. Then start Intralink, which will create a new, empty .proi.
Create a new workspace, check out the project You were working on.
Then, import the required files from th old .proi subfolder, overriding the files in the workspace (override any 'same name exists' conflicts).
That will take some time and manual tweaking, but usually works.
