Dear All,
is it possible to change a family table item by a pro-programme or by a map key??
Suppose that i have inserted a bolt of M24 x 60 in an assembly.
Now i want to chage it to M20 x 80 (the bolt is made by family table) automatically.
Is this possible by a pro-programme or by a map key or any other way automatically?????
Please help me.
You can use Replace in the Edit menu. You select the component to replace, choose to replace by family table and then pick the new instance.
You can also do it in Pro/Program, if you really want to do that. Let me know if you really need Pro/Program and I'll look up the specific details.
Thank u daryl.
i already knows the replace option but i want to do it in a single input by just feeding the size suppose "M 24x120",not manualy.
Do u have any thing regarding this related to pro programme or by an excel input please share it with me.
Hi, try to check my post - http://communities.ptc.com/message/219844#219844 ![]()
You can do this in the relations also. If you want the M24 bolt in one instance and the M20 in another you can create a parameter i will call it "bolt_size" and use an inst_lookup relation to control it.
You can set up a program that interchanges components through an INPUT statement structure.
For example:
INPUT
BOLT_SIZE STRING
"Enter BOLT SIZE"
END INPUT
In the associated ADD statement, put the name of the string variable.
For example, to add a part specifically to the assembly:
ADD PART (BOLT_SIZE)
END ADD
