You need the ISDX module for this. Using WF 3.0 (I do not have WF 4.0), first select the Style icon and then select Styling --> Trace Sketch (see help menu for more information). Images (JPEG, PNG, etc) can then be open into a view corresponding to a specific Datum plane (front, right, and top).
If you do not have the ISDX module, the other option is to use the decal tool (http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=37234&KW=decal) and place the decal on a flat surface before tracing over it. If you want to transfer a logo to a part surface using a decal or bump map, I discuss this in the following link: http://www.appianwaytech.com/blog/2010/02/26/tips-and-tricks/94
Chris
In Reply to Norbert Gruman:
Hi everyone
Probably a simple solution to this need. I have not had to do this until now. I need to import a jpeg onto a surface and cannot figure out the menu pics in WF4.
TIA
Norb
