locating hidden solid & surface bodies in Pro-E (similar to SolidWorks)
ptc-726111
I have a Pro-E question that may have once know the answer to, but I do not
remember as I have mostly been using SolidWorks lately. In a SolidWorks
part, a folder for both surface bodies and solid bodies exists (below the
annotations folder) listing all the surface & solid bodies contained in the
part model. The reason this is important is if some surfaces need to be
merged, you can go directly to the surface bodies in the folder, select and
then merge them together. You always know how many surface and solid bodies
exist in a part at a glance.
Concerning Pro-E (WF 3.0 or 4.0), what is the most direct method for
locating finding all unmerged surfaces in a Pro-E part where some may not be
visually obvious (example: obstructed by a solid body) when using hybrid
modeling techniques (solids & surfaces)? As I do not see any folders in
Pro-E indicating the number of solid or surface bodies, how do you go about
locating one that may be hidden from view?
Also, I have heard in Pro-E WF 4.0 that multiple surface bodies can be
merged at one time (Pro-E WF 3.0 only allows two at a time), is this correct
as it would reduce the number of features in a part? In SW, I can knit
several surfaces using one feature, so I wanted to verify this is also true
in Pro-E.
Thanks for your help.
Chris Thompson, CSWP
Appian Way Technologies LLC
Powell, Ohio 43065
www.appianwaytech.com
(614) 595-3751
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 6365 (20110810) __________
The message was checked by ESET NOD32 Antivirus.
0 REPLIES 0
