m170 fixes drafting problem
davehaigh
I got an email from PTC that they have finally fixed a problem I submitted back in March. I've downloaded version m170 and tested the fix.
This version fixes a problem with how datums are attached to gtols.
[cid:image002.png@01CB7FE4.F34E3110]
You can update old drawing by adding the following to the detail setup file:
update_drawing 1965861
In the case above doing this changed the origin to the center of the gtol, but maintained the offset, so I had to drag the datum back to the center of the gtol.
All new drawings should behave correctly.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
0 REPLIES 0
