model check not working
ng-2
hello
          i have already configured modelcheck settings in creo 3.0 and also i was working on it, accidently my liscence lost occoured and i reinstall creo 3.0 but after that model check is not working with creo, i have also placed config file in the defined location but still its not working, plese help to find out the solution...
regards
nimish
ng-2
(To:ng-2)
Actually i dont know what happened i also restarted machine but it was not working then i shut down machine for sometime, and then it works fine. dont know what happened at that time...
6 REPLIES 6
MartinHanak
(To:ng-2)
maybe it is licensing problem. Check whether your license contains ModelCHECK License.
MH
Martin Hanák
MikeLockwood
22-Sapphire I
(To:ng-2)
Pretty sure that all Creo licenses include MC.
Have to have it enable in both config.pro (modelcheck_enabled true) and modelcheck file config_init.mcc.
Mike is correct - no license needed to run MC other than a base Creo license.
Maybe the config files that you thought were being read weren't.
You can press the arrow next to the file you ran against to see which ones were read.
From page 136 of ReUse Your CAD: The ModelCHECK Handbook
Mahesh_Sharma
22-Sapphire I
(To:ng-2)
Nimesh,
When executing MOdelCHECK is there any message in message area?
ng-2
(To:ng-2)
Mahesh_Sharma
22-Sapphire I
(To:ng-2)
Nimesh,
Marking your comment as correct answer for post as you corrected the problem on own.
