In the ".prt" Model Tree, how can I modify features that under their "expand arrow"
there is only the "section 1" name and not a "Sketch" to modify.
Select Section 1, Right Click on that and Edit Definition, it will switch to sketch mode for section.
The section is the internal sketch of the feature. As @cgoshorn3 mentioned, you can select the section > RMB > Edit Definition, which will take you into Sketcher mode. You can also, select the feature > RMB > Edit Definition > RMB > Edit Internal Sketch.
Amit
How do you go from "sketch" to "section"??
By selecting a sketch when prompted for a section in defining a feature.
