modelcheck error
columicious
modelcheck error
I'm getting an error when running model check on an assembly (312453).
There are no datums at the assembly level (other than the 3 default
planes). Anyone know how I can troubleshoot this and get it resolved?
Thanks!
jellis
(To:columicious)
Stacy.....it may be difficult to offer much help without knowing more about your check files. Regen_Errs result from regeneration issues. Typically there is a message in the ProE message window when you have Regen_Errs. Are you getting anymessages in the message window that might point you to the feature it is having trouble with? Another option, perhaps, view the Ref Viewer and check for missing refs.One might think that"Datum placement error in model" would indicate an issue with refs used to place the datum? Maybe....maybe not?
Regards, Jim
