I am looking for functionallity that used to exist in pre wildfire and wildfire but can't find in creo.
In prewild fire it would be surface operations / transform / move. In Wildfire it was "edit"/ move (rotate, etc)
In Creo 2 - I don't see it !!! For my example, I want to create a copy of a surface and offset it so that I have a duplicate. This use to be so easy, now I just can't find this capability. Very frustrating - I appreciate any help
Scott
I found it... don't want to start an unnecessary thread showing that my impatience with exploring menus is leading me to frustration. Needless to say, that it can in fact be done. I found that you must first select the surfaces of interest (nothing new there) then copy and paste (yes, yes) ....now for the interesting part! ....then you must select this pasted copy and copy it again, THEN you may use paste special (previously grayed out) to transform (move or rotate) and if you are interested, beyond that you may copy the original which leaves the original in place or not which simple leaves you with one moved surface under the options tab. So happy that I could answer myself...
Thank you for your reply. In fact, offset is a different function from what I was looking for, but I did find what I was trying to do.
Offset is similar to a thicken feature, so a sphere with a 1" radius offset .25" would create a sphere with 1.25".
My objective was to select the that sphere and make a duplilate (say .5") away from it.
I do appreciate your rapid help.
