I have a dimension being controlled by a "multi level" parameter. It is similar to as shown below:
d3154=LENGTH
Parameter "LENGTH" is derived by another parameter. Its name is named "LENGTH_MORE"
"LENGTH_MORE" parameter is derived from a combination of text as well as other parameters.
The syntax in the relations for paramter LENGTH_MORE looks like this:
LENGTH_MORE= LENGTH_A + "_1X:FID_PARENT_SETUP:0"
So within the paremeter LENGTH_MORE it is pulling another paremter (LENGTH_A).
For the purposes of this question LENGTH_A=R4
The final value of LENGTH_MORE (after combinding the data above) may look something like: "R4_1X:FID_PARENT_SETUP:0"
Now: As you can see there is the ":0" at the end of the statement. That is I am pulling parameter "R4_1X" from feature id "PARENT_SETUP" within another part.
I can get the parameter LENGTH to have the correct syntax (in this instance it would show up as R4_1X:FID_PARENT_SETUP:0.
When I place the statement d3154=LENGTH. I get the error "invalid left side of assignment". I think it has something to do with the fact the parameters are switching to string but am unsure what the issue is.
