Hi alls,
I'm making some drawing templates for Sheetmetal parts.
So is it possible to prepare templates for having final part on first page and flat pattern on 2nd page (xxx_flat1 instance) ?
If yes, how to do ?
If not, how do you handle this ?
Dominique
Not as such -- instantiating a drawing template is done with exactly one solid model. You could (albeit with more steps) have two templates, one for the first page, one for the second. File>New>Drawing twice to make one then the other, and employ [Layout tab] Insert > Import Drawing/Data to merge the second page drawing to the first page drawing.
