multiple BOM repeat regions for subassemblies in one drawing
patrick.finn
Is there a way to put multiple BOM' in one drawing. I have a top level assembly with a couple sub assemblies in it. On the first sheet, I have the top level BOM with associated ballons. On the second and third sheets I have sub-assemblies. I would like to put in a BOM for the sub-assembly that is shown on that sheet and them put ballons associated with it. I am able to put in the table BOM but when I create the ballons, it asks me to select the repeat region. When I select the table, it gives me the message that "This is not a BOM balloon region". Does anyone know how to do this?
Under Table, Repeate Region..., The third menu item is Model / Rep where you can set the active model and rep for that specific table.
David Haigh
