opening a drawing in parametric 8 made in parametric 7 change some dimensions
Vermont_95
hello all
we are working since 2 weeks in Creo parametric 7  but our cad worker admin installed a Creo parametric 8 version for the cad worker.
today we see some differences between what we have in Creo parametric 7 and the viewable made.
see screenshots
if I open this drawing in Creo parametric 8 I can see also those modifications
questions:  is there a config option to avoid this behavior on the cad worker?
i tried :auto_clean_shown_dimensions no
USE_V19_CLEAN_DIMS no  also USE_V19_CLEAN_DIMS yes
without results.
seems related to flat  definition on sheet metal so what is different in creo parametric 8?
thanks for your help
2 REPLIES 2
By the looks of it the left 45° dimension in Creo 8 is referencing to a tiny vertical line, not the horisontal surface of the part, that's why it ends up below and not to the left. Or am I misunderstanding the issue here?
(I can't double check this as I do not have Creo 8 myself, only 7)
  • start Creo 7.0 without config.pro and open the drawing
  • start Creo 8.0 without config.pro and open the drawing
  • compare results
If you can upload test model+drawing, please do it.
Martin Hanák
