part number in multiple sheet drawing
thlavinka
I use multiple sheet drawings and would like to automate part numbers on all sheets according to a relation in parts and subassemblies (the part number must be same on each sheet).
I made this relation: part_number="415-"+rel_model_name:1+"-12"
Is there some way to fix the underscored number to remain always 1?
Thanx in advance
Tom
StephenW
(To:thlavinka)
One other thought somewhat off the original question. You might consider using the drawing name instead of the model name. Just a thought, it really depends on exactly what you are trying to accomplish.
14 REPLIES 14
SYNDAKIT
(To:thlavinka)
1 is the session id of whatever assembly you are using. could you explain more about what you want in the end exactly?
In each subassembly and part drawing sheet i want to have the same as on the first sheet (what is a top assembly) it means 415-"+rel_model_name:1+"-12 where the rel_model_name is the model name of top assembly.
mender
6-Contributor
(To:thlavinka)
What is it that you want to be same?  Is it 'the text in a note in a particular table cell in the title block part of my format'?  (That's my best guess right now.)  Or something else?
yes, right that..
mender
6-Contributor
(To:thlavinka)
Sounds good.  So I'd say your title block in your template drawing or format contains "415-{0:&DWG_TOP_MODEL_NAME}-12" (or depending on your intent for future drawings, "&DWG_TOP_MODEL_SHOWN" with a relation constructing param dwg_top_model_shown from dwg_top_model_name.
For bonus points, you can drive this parameter in the drawing from a parameter in the solid.  From Creo 2 M150 or Creo 3 M040, you can put the syntax 'DWG_TOP_MODEL_NAME:D = REL_MODEL_NAME:MDL' in your Drawing Program in your template drawing, not needing to have a solid model yet, and it will link to the first solid model you put in the drawing.  In these builds and later (this is when ':MDL' is introduced), you can also put this directly in the table in the template, as "415-{0:&REL_MODEL_NAME:MDL}-12".
Thanks Matthew
My creo version is Creo 2.M120.
Since i am not good at relations can you please describe exactly what destinaation to put each relation in?
- "415-{0:&DWG_TOP_MODEL_NAME}-12"  to the drawing format - that is clear
theese two relations i am not sure
- "&DWG_TOP_MODEL_SHOWN"
- dwg_top_model_shown from dwg_top_model_name
Thanks a lot
mender
6-Contributor
(To:thlavinka)
Exact syntax is difficult when it isn't clear what exactly you're looking for, like whether the '415-' and the '-12' will vary between different sets of drawings.  If you don't want to deal with relations, you should probably do the '90% value with 10% effort' approach and just have the note have a callout of the drawing parameter, and fill in the parameter manually once for each (however-many-sheets) drawing.
the '415-' and the '-12' will never vary.
here is an example: the top assembly model name is 473-1111 and desired drawing number should be 415-473-1111-12
StephenW
(To:thlavinka)
If your drawing file name is 415-473-1111-12.drw, you can use &dwg_name to get that output.
StephenW
(To:thlavinka)
How simple, thank you Stephen
It is enough to use the syntax like 415-&dwg_name-12 in dwg format
kdirth
20-Turquoise
(To:thlavinka)
I sometimes run into the same issue.  I have found that you need to ensure the active model in the sheet is the correct model needed for the title block when the format is added/updated.
I just need to ensure that all sheets have the same title name and number as the first sheet (top assembly) no matter whether it is a subasm drawing, part drawing, scheme,...
BenLoosli
(To:thlavinka)
Put a relation in your drawing file then use your new drawing name for the drawing sheets.
Sheet_Number = '415-'+&dwg_name+'-12'
Then use Sheet_Number on all drawing sheets for the part number and all sheets will be the same.
