I use multiple sheet drawings and would like to automate part numbers on all sheets according to a relation in parts and subassemblies (the part number must be same on each sheet).
I made this relation: part_number="415-"+rel_model_name:1+"-12"
Is there some way to fix the underscored number to remain always 1?
Thanx in advance
Tom
One other thought somewhat off the original question. You might consider using the drawing name instead of the model name. Just a thought, it really depends on exactly what you are trying to accomplish.
1 is the session id of whatever assembly you are using. could you explain more about what you want in the end exactly?
In each subassembly and part drawing sheet i want to have the same as on the first sheet (what is a top assembly) it means 415-"+rel_model_name:1+"-12 where the rel_model_name is the model name of top assembly.
What is it that you want to be same? Is it 'the text in a note in a particular table cell in the title block part of my format'? (That's my best guess right now.) Or something else?
yes, right that..
Sounds good. So I'd say your title block in your template drawing or format contains "415-{0:&DWG_TOP_MODEL_NAME}-12" (or depending on your intent for future drawings, "&DWG_TOP_MODEL_SHOWN" with a relation constructing param dwg_top_model_shown from dwg_top_model_name.
For bonus points, you can drive this parameter in the drawing from a parameter in the solid. From Creo 2 M150 or Creo 3 M040, you can put the syntax 'DWG_TOP_MODEL_NAME:D = REL_MODEL_NAME:MDL' in your Drawing Program in your template drawing, not needing to have a solid model yet, and it will link to the first solid model you put in the drawing. In these builds and later (this is when ':MDL' is introduced), you can also put this directly in the table in the template, as "415-{0:&REL_MODEL_NAME:MDL}-12".
Thanks Matthew
My creo version is Creo 2.M120.
Since i am not good at relations can you please describe exactly what destinaation to put each relation in?
- "415-{0:&DWG_TOP_MODEL_NAME}-12" to the drawing format - that is clear
theese two relations i am not sure
- "&DWG_TOP_MODEL_SHOWN"
- dwg_top_model_shown from dwg_top_model_name
Thanks a lot
Exact syntax is difficult when it isn't clear what exactly you're looking for, like whether the '415-' and the '-12' will vary between different sets of drawings. If you don't want to deal with relations, you should probably do the '90% value with 10% effort' approach and just have the note have a callout of the drawing parameter, and fill in the parameter manually once for each (however-many-sheets) drawing.
the '415-' and the '-12' will never vary.
here is an example: the top assembly model name is 473-1111 and desired drawing number should be 415-473-1111-12
If your drawing file name is 415-473-1111-12.drw, you can use &dwg_name to get that output.
How simple, thank you Stephen
It is enough to use the syntax like 415-&dwg_name-12 in dwg format
I sometimes run into the same issue. I have found that you need to ensure the active model in the sheet is the correct model needed for the title block when the format is added/updated.
I just need to ensure that all sheets have the same title name and number as the first sheet (top assembly) no matter whether it is a subasm drawing, part drawing, scheme,...
Put a relation in your drawing file then use your new drawing name for the drawing sheets.
Sheet_Number = '415-'+&dwg_name+'-12'
Then use Sheet_Number on all drawing sheets for the part number and all sheets will be the same.
